What should I do with this Philco 54 Cabinet?
https://dl.dropboxusercontent.com/u/9224...202931.jpg
 Get some paint and varnish remover, strip it off, and start over, unless you like the old whitewash look?
Send it to me for refinishing and I will send it back in about 2 weeks. PM for estimate Icon_clap Icon_crazy Icon_eek Icon_eek
strip it off, and start over.
Hay-ho, and up she rises
There are currently 10127 online users. [Complete List]
» 2 Member(s) | 10125 Guest(s)
