philco mod. 20 trimmer cap advice
Wondering if anyone can tell me if I should replace the mica on this trimmer that goes on the tuning cap. There is 3- on it and the one on the left is partially torn .Thanks
http://s1336.photobucket.com/user/220koh...k.jpg.html
looks like a good capacitor to me.
Thank you
There are currently 5109 online users. [Complete List]
» 1 Member(s) | 5108 Guest(s)
