What model is this?
Don't know how many tubes it has, I just like the Deco styling and the condition.  Common or not so common?
[Image: http://www.surfacezero.com/g503/data/500...onsole.JPG]
28L or 32L, or 38L. The year of 1935.
Not exactly rare, not too common either.,
Nope, the knobs are too close together to be a 28 or 38.
It could be a 32L...
...but, most likely, it is an 89L from the 1935 season.
A model 32 is a modified 89 chassis with a separate power supply, designed to operate on 32 volts DC. If it is a 32, the power supply will probably be mounted on a separate shelf inside.
http://www.philcoradio.com/gallery/1935a.htm#ag
Thanks guys. For an original finish radio, I'm hoping it would come back a little bit with a bit of work with Gojo and a little polish.....I prefer original finish radios whenever possible, but I do have several refinished sets in my collection.
Hoping that the speaker cloth is original as it seems to be in real nice condition.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 3698 online users. [Complete List]
» 4 Member(s) | 3694 Guest(s)
AvatarAvatarAvatarAvatar
