41-623 BOL
Here is a link to another source for the photo cell.
http://myarduinoonline.com/udt-silicon-p...l?cPath=78
Crist
hey greg
I don`t know if these will work but I`m going to try
http://www.ebay.com/itm/Selenium-photo-s...fresh=true
sam
There are currently 4506 online users. [Complete List]
» 2 Member(s) | 4504 Guest(s)
