Threads: 22
City: Waxahachie, TX
I applied the trim color today. I went with Perfect Brown toner but I thought it could be a little darker, so shot a couple of light coats of Extra Dark Walnut. The color is now a deep brown, not black, but darker than a solid brown.
One thing that I noticed is that on the front where I masked off the bottom trim, when I pulled off the tape, there is a definite lighter area where the tape was. Any good ideas as to how to fix that?
[Image: http://i1060.photobucket.com/albums/t458...q9rscy.jpg]
[Image: http://i1060.photobucket.com/albums/t458...mytjsj.jpg]
Crist
Threads: 147
City: Dallas, TX
Threads: 22
Threads: 22
Here is the cabinet after I shot a couple of coats of Mohawk E-Z Vinyl Sealer. I wish I would have done a better job with the grain filler. oh well, not bad for the first one though.
[Image: http://i1060.photobucket.com/albums/t458...ujm1s5.jpg]
[Image: http://i1060.photobucket.com/albums/t458...1gnlpj.jpg]
Crist
City: Sedona, AZ/Placentia/CA
Looks mighty fine so far Crist.
Jerry
Threads: 22
(08-30-2015, 05:49 PM)jerryhawthorne Wrote: Looks mighty fine so far Crist.
Jerry
Thanks Jerry!
Crist
Threads: 147
City: Dallas, TX
Threads: 22
Threads: 22
Threads: 147
City: Dallas, TX
(This post was last modified: 08-31-2015, 09:10 AM by Fred Taylor.)
Threads: 22
(08-31-2015, 08:58 AM)Frederick W. Taylor Wrote: (08-30-2015, 08:50 PM)Crist Rigotti Wrote: (08-30-2015, 07:18 PM)Frederick W. Taylor Wrote: Looking good Crist, don't for get your Philco decal before you start clearing, and you need to sign it also before clearing, your a true artist ![Icon_wtf Icon_wtf](https://philcoradio.com/phorum/images/smilies/icon_wtf.gif)
Thanks Fred. I was going to shoot maybe 5 coats of clear then add the decal. Would that be ok?
Hello Crist, 2 coats of clear would be enough. The more clear over decal the better , it will hide the cut line on decal better. I really like that EZ lacquer vinyl sealer from mohawk, it tends to fill better than there regular sanding sealer and is alot more durable . Now just sand lighly with 400 and shoot 2 coats of the buffcoat .
OK, I think I'll shoot the topcoat clear tomorrow. Getting close!
Crist
Threads: 22
I put on the decal before any top coat was sprayed. I then sprayed on 2 wet coats of Mohawk Buffcote sheen 40 thinned about 60% top coat and 40% Mohawk reducer. When those coats were dry, I lightly sanded then cabinet and then shot 4 more coats. The cabinet is finished. I'll take better pictures later.
[Image: http://i1060.photobucket.com/albums/t458...d1bhmq.jpg]
[Image: http://i1060.photobucket.com/albums/t458...uwfond.jpg]
[Image: http://i1060.photobucket.com/albums/t458...cpepls.jpg]
Crist
Looks perfect Crist! Very nice job.
jerry
Threads: 55
City: Lexington, KY
Threads: 69
City: Kansas city, MO.
Great job Crist. I have followed your thread from the start. You did a lot of work and it has payed off.
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10221 online users. [Complete List] » 2 Member(s) | 10219 Guest(s)
