Schematic for 48-475
It appears NostalgiaAir doesn't have a schematic for the 48-475. Can't find it in my Rider's either. Anyone have one? Thanks
Pat
Pat, there is one on the audiophool Philco schematics site . You need to download the dejavu reader. If you have trouble, i can post a pdf of it.
(09-03-2015, 07:23 PM)klondike98 Wrote:  Pat, there is one on the audiophool Philco schematics site .  You need to download the dejavu reader.  If you have trouble, i can post a pdf of it.
Forgot all about that site. Got it. Thanks
There are currently 5936 online users. [Complete List]
» 2 Member(s) | 5934 Guest(s)
