philco 42-1008 code 122
hey guys
on the back of 42-1008
their is a box with a switch
looks like it just plugs in to plug on chassis  any clue Icon_question Icon_question
I have not recapped to find out
  [Image: http://i1303.photobucket.com/albums/ag14...d4e9zi.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...aw2gjk.jpg]
sam
That is an antena switch. Someone recently posted a thread with the scematic on here
http://philcoradio.com/phorum/showthread...h#pid93591
thanks tab
I don`t know how I missed that section Icon_sick
sam
There are currently 4302 online users. [Complete List]
» 2 Member(s) | 4300 Guest(s)
