Philco 116B Dial Escutcheon/Glass Dial Cover
I have a 116B that needs a dial escutcheon/dial glass cover. I saw one for sale for a Philco 645. Are these interchangable? They both appear to hav a shodow meter.
Thanks!
Allen
No, they are not the same. The 116 requires a larger (taller) escutcheon than the 640.
Thank you Ron, you just spared me from buying the wrong escutcheon. Are there other models that use the same size escutcheon as the 116B?
Thanks!
Allen
Only the following use the escutcheon you need:
116, 660, 665, 680.
Ron:
Very helpful. As always, I appreciate your time and extensive knowledge.
Allen
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
