Replacement chassis spacer for Philco 70
Has anyone found a good replacement for the gum rubber chassis spacers?   I know RR sells a few different sizes, just wondered if anyone found a good fit?
Thanks
~Jon~
There are currently 5067 online users. [Complete List]
» 1 Member(s) | 5066 Guest(s)
