Threads: 113
City: The Villages
I'm at the point where everything I touch turns to s**t!
I've got a simple Airline model 4705 . Just a simple 6 tube AM radio. Replaced all caps. Tubes and resistors checked OK. Alignment done. Everything is fine except I only get one station . It is WGN, 720 from Chicago (about 40 miles away). It comes in on any dial position.  It is just as strong at 55khz as it is at 1600khz.
Any clues as to where to start?
Thanks guys,
Eric
The Villages, FL
Threads: 72
City: Linn Creek, MO
Sounds like the oscillator is not working. Have you tried placing another radio near it to see if you can pick up the oscillator?
M R Radios C M Tubes
Threads: 113
City: The Villages
Well Steve, I just checked it. The oscillator is working, but now WGN is gone and the only thing I can pick up is my SSTRAN set at 1500khz. This would be a step in the right direction except that it is coming in at about 700khz no matter what I do to the osc trimmer on the tuning cap!
Eric
The Villages, FL
Threads: 72
Eric, when you listen to the oscillator on the other radio and adjust the trimmer, does it move up and down the dial?
City: Sedona, AZ/Placentia/CA
Eric, do you have a signal generator? A very nice piece to have to troubleshoot these problems.
jerry
Threads: 113
City: The Villages
Sure do, Jerry. I was able to do the IF alignment.
Eric
The Villages, FL
Great Eric, now use it to run AM frequencies into the antenna input but please use an Iso trans on the radio. As you know, this has a potentally hot chassis depending on the plug orientation. Steve is much smarter and there is something wrong in the RF/OSC section. See what you find for a "tone" across the AM band.
Jerry
Sorry, Dup. And sorry Eric if I didn't realize and recognize your experience and knowledge. Best, Jerry
(This post was last modified: 09-22-2015, 09:48 PM by jerryhawthorne.)
Threads: 567
Eric, go save Midas
Threads: 54
Schematic linked to is an Air King 4705, not an Airline, or is your set actually an Air King? If so try replacing the 22k Ohm resistor on pin #1 of the 12SA7 tube. The 22K resistor, or R3, may test fine cold, but may not when the set is powered up.
Threads: 113
City: The Villages
Yes Arran, it is an Air King. The 22k ohm resistor is on pin #3 of the 12SA7 tube. It goes from pin #3 to ground. I replaced it. No change, except now it is motor boating.
No big deal. It is time to put it on the punishment shelf  and go on to something else.
Thanks for your help,
Eric
The Villages, FL
Threads: 416
City: Boston
I think as a kid I wound up on that shelf. I read a story/interview with a guy who worked at Air King, trouble shooter and supervisor on the line and while they did make some decent stuff they did cut some corners. It may be that some manufacturing may not be to spec or done well to begin with. Sometimes taking a break is good, think about it, work on something else for a change.
Good luck.
Threads: 113
City: The Villages
I think we all ended up on that shelf at one time or another  It's just that if this keeps up it looks like I'm going to need more shelves!
Eric
The Villages, FL
Threads: 92
City: Clayton, NC
This could be the result of an alignment mis-adjusted to an harmonic of the frequency vice the frequency itself. Also, how do you verify that the F is what it should be.
Threads: 92
City: Clayton, NC
What I mean is do you verify the frequency from your sig gen with a frequency counter?
Milkjug plastic?morzh — 09:36 PM |
Yep.
'Cause when I heard "buibble" I immediately thought of this
and started wondering how this poly...morzh — 09:33 PM |
Blister Pack, that's what I was trying to remember!RodB — 09:29 PM |
In the packaging biz we refer to the package as a clamshell or blister pack if on a cardboard. So we are using the packa...Paul Philco322 — 08:13 PM |
It’s been too cold to solder in the garage the last couple of evenings, but it has allowed me more time to search for th...jrblasde — 07:23 PM |
The part/tool you get from HD is inside the plastic, like in a bubble.RodB — 07:17 PM |
Got it. Still did not get the "Bubble" part.morzh — 07:10 PM |
No Mike. Clear plastic from the packaging of items you buy at Home Depot, the ones you can't open without a hack saw or ...RodB — 05:48 PM |
Philco 89 indicator light.
Well thankfully that did not happen.Jim Dutridge — 05:21 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
There are currently 8880 online users. [Complete List] » 1 Member(s) | 8879 Guest(s)
