Link to picture 116b-121
Lost all pictures of my 116b prior to disassembling. Need a picture
of complete dial assy so I can put mine together. I feel like such
a dunce. A link to a picture would be great. Icon_redface
Danny
Hi Danny,
Would this walk-through for rebuilding the 116B dial drive help?
http://www.philcoradio.com/tech/116dr.htm
I have a 116B chassis that I can pull out and take a picture if you need something more specific.
Nathan
Thank you this is just what the doctor ordered.
(09-23-2015, 04:09 PM)Nathan Slingerland Wrote:  Hi Danny,
Danny
There are currently 5980 online users. [Complete List]
» 3 Member(s) | 5977 Guest(s)
