Grill cloth for mod. 90 help
  Trying to finish up a mod. 90 philco and was wondering if this cloth is close to original. Thanks
http://www.ebay.com/itm/Antique-Radio-Gr...2a59c8d70c
I bought some of the same for my model 70 and, holding it up to the original, it looks very close.
Thanks Greg. I put an order in for some.
Glad you found that grill cloth. I used it on my 48-482 with the grain running horizontally, and lit looks great and is excellent acoustically. I think you will be happy with it. Good luck with your project ! Please post some pictures when done.
There are currently 10407 online users. [Complete List]
» 1 Member(s) | 10406 Guest(s)
