39-17 Grille cloth supplier?
Who has the most correct grille cloth for my 39-17 cabinet that Fred just finished for me?  What item number or name is it?  Thanks, Steve
[Image: http://www.surfacezero.com/g503/data/500...170350.JPG]
Looking at the Gallery photo of a 39-17 I was all set to suggest Radio Daze as a supplier but I no longer see the cloth on their web site that I was looking for ( I used it in a 39-25 I did and I'm 99% sure I got it from Radio Daze). Short of that I'd look at ebay and the folks that Ron lists on the Resources Page ....and there's always a trip to Joanne Fabrics where I've found a few items.
The original cloth was known as Philco "Ribbed" cloth. Bob ( klondike98 ) is correct, Radio Daze no longer carries this cloth.
I did find someone on the auction site who is selling cloth that is similar, and he says he is running out...
http://www.ebay.com/itm/300719399017
Thanks guys. I'll place an order with him.
Bret Menassa (think I spelled it right) is a good egg, he may have bought up the suplly when the Grille Cloth folks closed up. I am sure he gives a square deal. btw --Super Job by Fred!
Paul,
Thanks for the heads-up. He's the one selling the cloth on eBay. Same number Ron mentioned. I emailed him and it's him. I think I'll get a couple extra, in case he stops selling it.....
hey guys
this pattern  would be same for 250 and all bullet radios ?
sam
Same for any Philco using the "Ribbed" cloth which includes several 1936-1939 models.
Looks like RadioDaze has the ribbed cloth back in their lineup....
http://www.radiodaze.com/grille-cloth-14-item-grc14/
There are currently 9536 online users. [Complete List]
» 1 Member(s) | 9535 Guest(s)
