38-12 dial lamp antenna?
Lightbulb
This is weird!
Got a 38-12 on the bench, and there is a dial lamp socket wired between the antenna coil and ground,
with red and green wire about a foot long between the socket and the set, I wouldn't even be posting this
except the wire on the socket and solder connections in the set look virgin.
anyone see an antenna connection that is a dial lamp socket?
Weird, yea!
Keith
Can't say that I ever have. Does it light up???
(11-18-2015, 12:48 PM)Radioroslyn Wrote:  Can't say that I ever have. Does it light up???
I cant imagine it does, except maybe briefly when lightening hits nearby. There was no bulb in the
socket.  I think Ill leave it on, make a screw base for an antenna and have it as a conversation piece
when I sell it.  Part of the radio's history!
Keith
Well, by the time lightning got to the little bulb, even CSI Crime Lab couldn't find it, anyone remember "Lightning Arrestors?"
