Model 37-60 resistor #19 value. Any production changes/
Hello:
I'm working on a model 37-60. I'm wondering if there was perhaps a production change with resistor 19. All the literature says it should be 9K and 2 watts. What is in place is a 30K, 2 watt dog bone resistor. It looks original. There are some other elements that are slightly different. I was wondering if there were any changes in production.
Dave
schematic here: http://www.nostalgiaair.org/PagesByModel...013205.pdf
I'd stick with the value of R19 found in the set, provided it is original, and measures the same as indicated on the part; probably wouldn't make much of a difference in this case - certainly not a show stopper. From what I've seen, minor changes were made all the time depending on what parts were on hand, or to improve reliability/performance, and documentation for non critical stuff just wasn't done with regularity.
There are currently 5211 online users. [Complete List]
» 5 Member(s) | 5206 Guest(s)
AvatarAvatarAvatarAvatar
