116b cap polarity
schematic is here  http://www.nostalgiaair.org/PagesByModel...013122.pdf
caps (100) and (101 x 2) Can someone please tell me the proper polarity ? This has
always confused me, but I'm easily confused. Cannot read either of these two caps
because of rust and grime.  Both are isolated from chassis ground. Thanks in advance.
Danny
Caps 100 and the part of 101 that connect between the xfmr centertap and the choke have their plusses to the choke.
Cap 101 connected between the centertap and the GND. has its plus to the GND.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 3556 online users. [Complete List]
» 3 Member(s) | 3553 Guest(s)
