Philco 16B from the AHRS
Thanks! I just restored a similar 16B cathedral so I am happy to finally have something to contribute.
BTW - A surprisingly close replacement for the large rubber ring on the dial itself is the gasket from a Fram 3387A oil filter:
http://www.oreillyauto.com/site/c/detail...&ppt=C0023
There are currently 4945 online users. [Complete List]
» 3 Member(s) | 4942 Guest(s)
