Sylvania Ford model 2FC754
I'm working on this car radio that is having a problem with the second IF transformer, SMD, and I'm trying to figure out how to wire the thing back in. The thing appears to have had 4 capacitors, it had 6 connections going to it. With the mica disc gone it can no longer have the 6 connections. On the schematic the coil to left isn't a problem but the other seems to be and I'm scratching my head. Any suggestions on how to fix this thing?
I have added 2 pdf files to this thread, hopefully someone out there can help. It's the IF transformer that's boxed, and shows 4 capacitors in the IF can.
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4367 online users. [Complete List]
» 1 Member(s) | 4366 Guest(s)
