Bakelite Block Question
As long as I've been rebuilding bakelite blocks with success, I seem to be having a brain flatchulent.
3903-K .01 1-2-4-7 - - - - - - 1-7
This is the information for a 3903 k bakelite block. I'm confused at this point. Does this mean there is 1 .01 cap only in this setup that only utilizes connections 1 and 7?
73 de,
Gary/N9VU
Yes.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Terry Judkins Wrote:Yes.
Thanks Terry!!
73 de,
Gary/N9VU
