41-290 Auxiliary Input Jack Wiring
I am tasked with installing an auxiliary input for a Philco 41-290.  It will be a simple 1/4" switched jack.  The question is where would you break the circuit to wire in the 1/4" jack?  I would like to control the volume with the front knob.
I have attached the schematic.
Thanks!
Break the connection @ the blue wire, #38 and #39.  Audio input connected @ left of #38.
Awesome!  That's where I was thinking.  Just wanted to be sure.
Thank you!
There are currently 4222 online users. [Complete List]
» 2 Member(s) | 4220 Guest(s)
