116b cap polarity
schematic is here  http://www.nostalgiaair.org/PagesByModel...013122.pdf
caps (100) and (101 x 2) Can someone please tell me the proper polarity ? This has
always confused me, but I'm easily confused. Cannot read either of these two caps
because of rust and grime.  Both are isolated from chassis ground. Thanks in advance.
Danny
Caps 100 and the part of 101 that connect between the xfmr centertap and the choke have their plusses to the choke.
Cap 101 connected between the centertap and the GND. has its plus to the GND.
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
