Philco 90 (Early) Speaker Diagram
For reference, attached is the wiring diagram for the early Philco 90 with push-pull 45 output tubes:
The page in the tech section on Philco 20/70/90 speakers is very helpful but only has the diagram for the single-ended output versions:
http://www.philcoradio.com/tech/speaker.htm
The wiring on my 90 was pretty mangled, so it took a bit of tracing of the schematic to figure it out.
There are currently 3756 online users. [Complete List]
» 1 Member(s) | 3755 Guest(s)
