49-1601 AC input capacitor
Re-capping a 49-1601 which is transformerless.
Uses a voltage doubler power supply with a 50X6 rectifier tube and a 20uF input capacitor (C101).
The diagram shows positive (+) connected to one cathode and one anode and the other side of the cap to power line.
Parts list shows 400v/20uF.
Now, from my understanding of doubler supplies, this cap should be NON-polar, which could be internally two 40uF connected "back to back".
But the schematic I have just shows one cap, polar.
Does anyone know more about this?
49-1601 AC input capacitor - by Plutonius - 09-24-2016, 12:43 AM
RE: 49-1601 AC input capacitor - by morzh - 09-24-2016, 09:39 AM
Restoring Philco 96
There are currently 5613 online users. [Complete List]
» 5 Member(s) | 5608 Guest(s)
AvatarAvatarAvatarAvatar
