16B tuning problemos
Hi everyone! I have YET another problem with my resto. I rebuilt the tuning mech with the o-rings, and that part works PERFECT!
However, the rubber on the back of the dial wheel has, over time, stretched. So when I work the tuning, the rubber squirms around and will not meet the new O-rings properly. What I THINK I want to do is to whack a piece out of the rubber and re-glue it onto the dial ring so it will fit flush.
But I wanted to run this by my Philco friends first....is my plan the right one??
16B tuning problemos - by Guest - 10-19-2007, 10:43 AM
[No subject] - by Chuck Schwark - 10-19-2007, 03:22 PM
[No subject] - by Ron Ramirez - 10-19-2007, 10:11 PM
[No subject] - by 49Stude63 - 10-21-2007, 05:20 PM
[No subject] - by Guest - 10-21-2007, 05:46 PM
There are currently 8867 online users. [Complete List]
» 1 Member(s) | 8866 Guest(s)
