Stromberg-Carlson P-27285
Rocketeer is right on, those Octagons are desirable, fetch a good penny at the swaps. I would be curious as to the performance, build quality is usually good on SC's, maybe even on a simple style.
Good luck.
Stromberg-Carlson P-27285 - by morzh - 09-10-2013, 08:46 PM
RE: Stromberg-Carlson P-27285 - by morzh - 09-10-2013, 08:47 PM
RE: Stromberg-Carlson P-27285 - by TA Forbes - 09-10-2013, 09:22 PM
RE: Stromberg-Carlson P-27285 - by TA Forbes - 09-10-2013, 09:24 PM
RE: Stromberg-Carlson P-27285 - by morzh - 09-11-2013, 12:04 AM
RE: Stromberg-Carlson P-27285 - by Jamie - 09-12-2013, 07:12 AM
RE: Stromberg-Carlson P-27285 - by rocketeer - 09-12-2013, 09:06 AM
RE: Stromberg-Carlson P-27285 - by morzh - 09-12-2013, 09:25 AM
RE: Stromberg-Carlson P-27285 - by Jamie - 09-12-2013, 09:35 AM
RE: Stromberg-Carlson P-27285 - by rocketeer - 09-12-2013, 10:06 AM
RE: Stromberg-Carlson P-27285 - by morzh - 09-12-2013, 10:26 AM
RE: Stromberg-Carlson P-27285 - by PhilcoMike - 09-12-2013, 11:34 AM
RE: Stromberg-Carlson P-27285 - by morzh - 09-12-2013, 12:17 PM
RE: Stromberg-Carlson P-27285 - by TA Forbes - 09-12-2013, 08:58 PM
RE: Stromberg-Carlson P-27285 - by Paul Philco322 - 09-12-2013, 09:08 PM
RE: Stromberg-Carlson P-27285 - by codefox1 - 09-13-2013, 05:41 PM
There are currently 7297 online users. [Complete List]
» 3 Member(s) | 7294 Guest(s)
