Model 37-60 resistor #19 value. Any production changes/
Hello:
I'm working on a model 37-60. I'm wondering if there was perhaps a production change with resistor 19. All the literature says it should be 9K and 2 watts. What is in place is a 30K, 2 watt dog bone resistor. It looks original. There are some other elements that are slightly different. I was wondering if there were any changes in production.
Dave
Model 37-60 resistor #19 value. Any production changes/ - by Sourbone - 12-26-2014, 08:32 PM
