#76
Please get the fish paper. If the gasket material is exposed to moisture could be big trouble. Stay Safe David
#77
Ah, moisture is another consideration to which I was completely blind. I agree with David, it's certainly always best to use material which was designed for the application.
Joseph
Philco 46-480
Philco 49-906
#78
Speaking of moisture, Fish Paper is also somewhat hydroscopic, but I guess the electrical grade (what is called vulcanized fiber) should be ok.
At least I've not seen problems with it.
#79
My opinion is, if you go through all the tests to determine if another material MIGHT be an alternative, just buy the fish paper! Usually under $10.00 for enough for numerous projects. -Gary
I just bought some off of Amazon last week. It was delivered on Tuesday. I paid about $11.00 for it, and there's enough fish paper for multiple IF cans. At least 15 of them.
Joseph
Philco 46-480
Philco 49-906
#81
Back to the 46-480 restoration, I did make another observation. I had previously commented that R305 was an 18 Ω resistor when I removed it from my chassis. According to both the Philco schematic and parts list, as well as the Rider's schematic, it was supposed to be a 150 Ω resistor. At the time I decided I would keep with the 18 Ω resistor, since that was what was physically installed. However, I now believe that this resistor isn't original to the radio. For one thing, take a look at it (the resistor on top).
It's much shinier than some of the other typical resistors I removed. Now that I've discovered the AM-only Meissner IF can in place of the AM/FM Philco part, I am starting to picture that there was likely some sort of failure which prompted these replacements. I'm willing to bet that the serviceman who installed the 18 Ω resistor did so either out of error or to increase the gain of the signal being fed to the Meissner IF can since it is a double-tuned circuit compared to the unusual AM circuit in the Philco 32-4074 IF can. Thus, I now believe that I will match the 150 Ω value seen in the Philco documentation.
Joseph
Philco 46-480
Philco 49-906
#82
I will have to find that roll, which I got from a NAPA dealer years ago. It's not like the normal gasket paper in that it's the variety which would resist gasoline, or other fuels, for use in carburetor and fuel pump gaskets, which is what I used it for. it looks almost identical to fish paper, so I doubt whether ordinary moisture would be a problem. The reason I ask is that I took apart some IF cans in a Stewart Warner vibrator radio, and they had a cloth with a sticky varnish type substance on it rather then the typical fish paper, or varnished paper like your Philco had, and it made it difficult to get the covers off of the IF cans. Needless to say I removed them to get them back together, as I did not unmount the cans from the chassis. I'm curious about the electrical specs, if it has any at all, it's not a problem getting something else but I have basically a lifetime supply of the stuff. I may have to make a test rig, another trick to limit current is to connect a light bulb in series with the primary, though that will reduce the output voltage under load.
The B+ in the Stewart Warner is only about 180 volts as they used battery tubes rather then AC tubes like a Philco or Brand Z set would use. It was in a similar condition to your poor 46-480 rust wise, but the reason I started fixing it is that you could power one of these sets from a single 6 volt SLA battery so they are almost practical to use as a modern solid state radio. I also felt sorry for it, it was literally sitting on a junk pile, but it was also almost complete, only missing a single knob.
My PCBs were delivered for the multi-section capacitor replacements! The dimensions are just perfect. The elongated PCB lines up perfectly with the rivet holes, and the mounts for the four QC connectors on the circular disk align with the slots on the chassis for the original twist-lock lugs. Clearances look perfect (remember that the neutral pins, which are equipotential with the chassis) are the through holes which are closest to the edges.
I finished verifying all of the passive components yesterday, so I’ll get an order together on Mouser this evening. I’ll include the QC connectors and solder lugs for these two PCBs. Can’t wait to see them assembled and installed on the chassis!
Joseph
Philco 46-480
Philco 49-906
#84
Nice!
#85
I’ve gotten the parts in the mail, and so I now have the custom multi-section capacitors assembled and installed onto the chassis! I will say that the QC connectors were a bit thicker than I imagined, so they didn’t really want to twist. Not to worry, as I was able to bend them outward and then apply a small bead of solder to hold the assembly on the chassis.
Joseph
Philco 46-480
Philco 49-906
#86
I haven't posted the schematic in a long time. At long last, I am done with it. I've got two versions I will upload. The first version I've called Rev 0. In this revision, all I have done is digitize the original Philco schematic and make the necessary edits to reflect production run 9 (since that's the production run I have). This is also the final production run, so it's probably a good version of the schematic to upload for others to use, so that they can start from here.
The second version of the file I've called Rev 1. In this revision, I've added a polarized plug, moved the on-off switch to the live side of the 117 VAC primary circuit, and inserted a 1A fuse. I've also updated the values of a few of the capacitors to reflect the closest replacement values I could get (0.47 μF for C102 instead of 0.5 μF, as an example).
I've denoted the revision in the file name, as well as in the title block of the drawing. I also added revision blocks, to keep a running list of all updates to the drawing.
One final detail which I included was the wafer switch detail. I had to recreate it from scratch since this detail was blurry on the original Philco schematic.
Joseph
Philco 46-480
Philco 49-906
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 4672 online users. [Complete List]
» 1 Member(s) | 4671 Guest(s)
